diggerbucket
Message 1 of 12
BT 6500 unknown pin - not 0000
I have just set up a BT 6500 handset, the manual says the first time I go into Call Control it should prompt me to set up an access pin, but instead it is asking me for a pin and I am locked out.  It's not 0000 or 1234.
If I was guessing I'd say my "new" handset has actually been set up previously, it's the only reason I can think of that would make it like this.
Anyways, I need to get into my phone, the manual is no help, how can I reset it or otherwise?
11 REPLIES 11
Devon_Dave
Distinguished Guru
Message 2 of 12
Re: BT 6500 unknown pin - not 0000
Hi
Taken direct from the user guide.
1. Select
Menu, scroll to display Settings and
press
Select.
2. Press to highlight
Reset and press Select.
3.
H/set settings is highlighted, press Select or press
to highlight
Base settings and then press
Select
4.
Reset <handset or base> settings back to default?
is displayed, select
Yes.
5.
Resetting <handset or base> settings… is
displayed while the reset takes place. Once finished,
<handset or base> settings reset back to default
is
displayed.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
diggerbucket
Message 3 of 12
Dave,
Thanks, I had tried that reset on the handset already and it didn't work, hance my post, but I went through it again this time aso resetting the base, and I also picked the option to clear all user data.  That has done the trick.
Mickadoon
Message 4 of 12
Wow, thanks guys! I found a 3-handset BT8500 in a charity shop for £6, someone must have given up on it. But the PIN wasn't 0000 or anything else I tried, and I couldn't find a way to reset it until I found your post. I'd maybe have got there eventually but you made a puzzling task very easy, Reset User Data did the trick. Now I need to find out how to use it as a plain old telephone without the whistles and bells. Thanks again, Mike.
john46
Message 5 of 12
Try downloading its online manual
Fedup141
Message 6 of 12
Thankyou, I was directed to you message by someone else who was helping me and it worked
Freelandertd4
Message 7 of 12
Mickadoon
Did you get a solution to your pin problem as I have the same problem with my 6410 handset, the pin has been changed and I do not know how to reset it.
CJT80
Recognised Expert
Message 8 of 12
@Freelandertd4 Did you try the options on post: 29-12-2013 18h44 by @Devon_Dave ?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Freelandertd4
Message 9 of 12
I have been in touch with the BT help desk who have given me some options for resetting my 6410 but mine turns out to be a 6410 + handset so am waiting to see if their is another code to do this.
To reset the 6410 is MENU then type ( * 0 # 0 *) (this does not show on the screen) press BACK and it should now show support press OK , scroll down to RESET SYSTEM PIN press Okay , press BACK 3 times and the display should revert back to STANDBY. Remove and reinstert batteries and the pin should be reset to 0000.
Aitchie46
Message 10 of 12
Good straightforward instructions, five stars to you Devon_Dave
