Message 1 of 3
BT 8600 ANswer phone
HI Guys n Girls,
Want to purchase a BT 8600 but want to check how it informs you you have an answerphone Message. My current iDect phone just gives you a flashing envelope on the screen which is easily missed. Does the 8600 give you a flashing light or ring or anything useful like that.
Also if it is just a flashing icon do then have to press numerous buttins to get to the messages ?
THanks in advance
2 REPLIES 2
Message 2 of 3
Re: BT 8600 ANswer phone
Yes it beeps every so often and a green LED in base set lights up.  Also handsets tell you there is missed calls, blocked call and messages.
Message 3 of 3
Thank you much appreciated
