Message 1 of 3
BT 8600 system
Our BT8600 system has two handsets plus the previously existing corded handset, which still functions as part of the phone system, but not using the Call Guardian system. The three handsets have functioned fine for several years, but now, when there is an incoming call, sometimes (not consistently) the BT 8600 handsets will not pick up the call, and the display shows 'Line in use- a call cannot be made'. If this happens, the call can only be picked up on the old handset. Any ideas how to cure this?
2 REPLIES 2
Message 2 of 3
Re: BT 8600 system
@kevingrafton
Remove the power from the base unit for about one minute.
Message 3 of 3
Re: BT 8600 system
Many thanks for this, and sorry for delayed reply. I had already tried this on one of the base units (there are two, upstairs and downstairs), but it seems that it needed to be done with both units at about the same time. All now seems well (with crossed fingers). Most grateful for your help.
