borderline
Message 1 of 16
BT Broadband Helpdesk not 24 hours anymore?
I'm having issues with my BB connection, I've just called BT Broadband help and to my surprised I couldn't get thru anyone as a message said they are open only until 8pm !!!!
what the **bleep**? on the webpage it says 24x7 365 days... I've called them in the past after 8...
have they changed it now??? that's really bad
15 REPLIES 15
Webby
Message 2 of 16
Re: BT Broadband Helpdesk not 24 hours anymore?
What number did you call? It is indeed a 24 hour operation.
john46
Message 3 of 16
just called to test and yes it is open 08001114567
borderline
Message 4 of 16
I called 08001114567 then I pressed the options for techical adviser.... the phone rang a couple of times and then a recorded message said  that they are open from 8 am till 8 pm and then I was cut off. I tried several times, I was calling after 9 pmSmiley Sad
Webby
Message 5 of 16
It's definitely a 24 hour desk.
Andy_N
Distinguished Guru
Message 6 of 16
Hi.
If I had to guess, it sounds like that all the support people were busy, and hence the system diverts to a message. Unfortunately the message isn't right.
cordycordy
Message 7 of 16
there is STILL an issue with the 24 hour helpline - doesn't work after 8pm
sjtp
Guru
Message 8 of 16
Maybe the general helpline is 24 hours, but the (so called) technical advisors are not?
cordycordy
Message 9 of 16
when i call 151 or 08001114567 it just says BT is closed (calling re bt infinity problem)
website says
Call us
24 hours a day, 365 days a year.
The best time to call is
between 12 noon and 4pm.
Please make sure you're at your computer when you call.
  • From a landline: 0800 111 4567
  • From a mobile: 0330 123 4567*
  • From abroad: +44 179 359 6931**
john46
Message 10 of 16
i have just tried the help line number and got straight through
