Rawson007
Newbie
Message 1 of 2
BT Broadband Home Hub 2.0 + Apple AirPort Extreme.
Please can someone help me?
My BT router has to be downstairs connected to the phone socket obviously. My old PC upstairs will not allow me to install any form of wireless dongle and instead of hard wiring a cable all the way upstairs to the PC I have bought an Apple AirPort in the hope that BT can send the Internet wirelessly to my Apple Air Port (Which I would like to keep up stairs if possible) then my Apple Airport can be hard wired to my PC.
please help, thanks in advance 🙂
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Broadband Home Hub 2.0 + Apple AirPort Extreme.
Hi Rawson007,
Thanks for posting. I've done a quick google search and found the following. Let me know if it helps.
"First you will need the WEP key from off the back of the hub, make sure you use the correct one for your service, as there are 2 listed.
Then click on the airport symbol in the title bar and you should see the BT home hub listed, click on that and then enter the correct WEP key, ensure that you prefix this WEP key with a $ symbol, then click connect and away you go."
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
