Message 21 of 26
Re: BT Broadband/HomeHub 3 connection speeds
There is a definite buzz on the quiet line test.  I just plugged an old phone into the 'phone' socket of a BT filter.
Message 22 of 26
is it a corded or cordless phone
Message 23 of 26
Corded.
On hitting the physical mute button on the phone the line does go silent.
Message 24 of 26
ok that sound as though the line is ok
Message 25 of 26
Quick update..
Plugged the router into a single power socket, with no extension cables to rule out the possibility of dips in power causing the problem.  I checked the Hub stats before I left for work and it didn't disconnect overnight, but upon checking it now, I see it's only keep connected for 4.5hrs, so the problem persists.
I guess it's about time I call BT again, unless there's any more suggestions from you guys?
Thanks.
Message 26 of 26
Hi I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
