Message 1 of 18
BT Business Hub 5 - how to configure to use non-BT DNS servers?
Hi all, I wonder if you can help me please.
I have BT Infinity 2 Unlimited VDSL.  I have both a HH5 and a Business Hub 5 (latter bought on web auction site).  I want to use Google DNS (or other DNS servers) on the Business Hub 5 instead of BT's slow DNS servers.  I have tried changing the primary and secondary DNS servers to the Google ones (and then saving the configuration), but I'm not seeing any increase in speed.  Are there any other settings on the BH5 I need to change, eg DHCP, gateway IP, etc?  if so, what to?
(I originally got ~70Mbps wired to the HH5, but over the last few months am now getting ~55Mbps.  I have FTTC and am 160m from the cabinet.  I have contacted BT to get them to rectify this - they are 'still investigating'.  They say there's been no throttling.)
Thanks in advance for all genuine help/advice. My apologies if I haven't given sufficient or incorrect info.  🙂
Regards
pmet90
17 REPLIES 17
Message 2 of 18
Re: BT Business Hub 5 - how to configure to use non-BT DNS servers?
I doubt changing the dns servers will help with your actually connection speed
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
are you using test socket with new filter or do you have a SSFP (2 sockets)
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Message 3 of 18
Hi imjolly,
Thank you very much for kindly replying to my enquiry. Below are the details you asked for:
(1) Troubleshooting/Helpdesk/1-12
1. Product name:
BT Home Hub
2. Serial number:
+068343+NQ41808393
3. Firmware version:
Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 03/07/15
4. Board version:
BT Hub 5A
5. DSL uptime:
2 days, 23:55:06
6. Data rate:
15186 / 59408
7. Maximum data rate:
14989 / 59332
8. Noise margin:
5.8 / 6.4
9. Line attenuation:
19.8 / 13.2
10. Signal attenuation:
20.0 / 13.3
11. Data sent/received:
912.9 MB / 9.8 GB
12. Broadband username:
bthomehub@btbroadband.com
Straight away I can see number 7 - maximum (download) data rate is 59332! What the heck?! Has it been deliberately capped by BT? I clearly recall getting 70+ Mbps when I first signed up to Infinity 2. What gives?
(2) BTSpeedtest:
  1. Best Effort Test:
    Download Speed : 55.15 Mbps
    2. Upstream Test:
    Upload Speed : 13.11 Mbps
(3) Wholesale FTTC check:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number *********** on Exchange WANSTEAD is served by Cabinet 33
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
80
71.3
20
20
Available
FTTC Range B (Impacted)
80
66.8
20
19
Available
WBC ADSL 2+
Up to 5.5
4.5 to 6.5
Available
WBC ADSL 2+ Annex M
Up to 5.5
Up to 1
4.5 to 6.5
Available
ADSL Max
Up to 5
3.5 to 7.5
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Fibre Multicast
Available
Copper Multicast
Available
For all ADSL and WBC Fibre to the Cabinet (FTTC or WBC SOGEA) services, the stable line rate will be determined during the first 10 days of service usage.
(4) Quiet line test:
This was done (unfortunately only cordless DECT phone)- I couldn't hear any unusual sounds or crackling or anything like that.
I am using a double socket (which doesn't need a filter).
Why do you doubt that changing DNS servers will help with connection speed?
Thanks very much again in advance for all help/advice received. Apologies if I've given insufficient/incorrect info. 🙂
Regards
pmet90
Message 4 of 18
as you can see your speed and attainable are lower than your estimated speed but your line is not capped by BT.
you are on a Huawei cab which will have G.INP enabled and this with hh5a may be the reason for the drop in speed.  I can't find anything at the moment which says if the business hub 5 works like the hh5b with G.INP which may get speed improved
you could try business hub  change username to bthomehub@btbroadband.com and password BT
https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-G-INP/td-p/1460086
Message 5 of 18
Because DNS servers have absolutely no involvement whatsoever in connection speed. Changing DNS servers may improve web browsing speed but not connection speed which is determined by the physical characteristics of your line between your modem and the DSLAM in the green cabinet.
Expert
Message 6 of 18
There are occasions when using different DNS servers might help with connection speeds. A lot of large content providers and EA being one of them including Origin use different servers in different countries even with the same DNS name. Depending on the DNS hierachy you can sometimes get punted to a different country. A lot of people report better download speeds when using google DNS servers as it looks like you get resolved to the US where the latency for downloads might be higher but the speed appears to he higher, suggesting some contention with Origin's UK servers.
Message 7 of 18
That is not connection speed. Connection speed refers purely to the DSL speed.
Message 8 of 18
Hi imjolly, licquorice and Jonkarra,
Thank you all very much for kindly replying to my enquiry.
imjolly, I think you've hit the nail right on the head.
I did some reading up on the G.Inp issue, which suggested that the Openreach Huawei HG612 3B modem could indeed cope with it. So I tried connecting my HG612 3B (which came with my HH3) as the VDSL modem and using the HH5A as a router only. Voila, I'm now back up to around 63 Mbps (from 55 Mbps), so I'm leaving it like that for now. 🙂
I haven't tried the BH5A again, as I understand it's exactly the same physically as the HH5A (chipset etc), only the firmware is different (can anyone please confirm this?).
The BT fault/technical team have phoned me a number of times over the last week in response to my slower broadband fault report, they claim not to have heard of the G.Inp issue. Earlier today I asked them not to bother any more with pointless exchange/line tests and "fixes", all of which have been done repeatedly with no result. I asked them to simply arrange for a BT engineer to come round as soon as possible to officially confirm the G.Inp issue is present, and then once that's done for BT to send me a freebie 5B to replace the 5A.
With regards to changing the DNS servers, all I want is to speed up access to web sites. If anyone has any further info on doing that successfully using a Business Hub 5 (A or B), please could you let me know?
Once again thanks very much in advance for all help/advice received. Apologies if I've given insufficient/incorrect info. 🙂
Regards
pmet90
Message 9 of 18
the hub 5a and 5b have different firmware and chipsets there is no point in getting an Openreach engineer visit as there is no point and you could well be charged for the visit you have found the problem yourself by using the modem
also you are not likely to get a hub 5b if you ask for one as they send out the first available hub be it an a or b the call centre has no control over it
Message 10 of 18
I would stick with the modem and router as many others have done. If BT did agree to send a new hub it is 50/50 whether you get an a or b
