AnnieWaring
Message 1 of 2
BT Cal Protect issues
Hi, i have been on BT Call Protect for a while now, does anyone know if you black list a number then that person rings you, what message do they get?
1 REPLY 1
pompey1898
Recognised Expert
Message 2 of 2
Re: BT Cal Protect issues
This was the response from NeilO at message 62 of https://community.bt.com/t5/Phones/BT-Call-Protect/td-p/1708063/page/7
Thanks for your questions regarding the BT Call Protect messages. The message the caller gets if you blacklist a number or if its blocked by BT is the same and the message is as follows: Welcome to 1572 the person you have called has chosen not to receive certain types of calls a message can be left after the tone.
If you have turned on 'unrecognised' calls in the call type menu withheld and number unobtainable calls will be diverted to your junk mail box and the message the caller will get is slightly different: Welcome to 1572 the person you have called has chosen not to receive anonymous calls, please dial again without withholding your number or leave a message after the tone.
