joebhoy
Message 1 of 2
BT Cloud. Backups
Hi, whats the frequency or time when a backup checks for new files in a backup folder ? Is this only on Startup ?
1 REPLY 1
joebhoy
Message 2 of 2
Re: BT Cloud. Backups
OK, after testing it seems this software only starts another backup check once it has restarted. So If Ieave my machine on for 5 days it wont backup in this period. Can someone from BT confirm this is the expected action of software. I believe I read the backup function should monitor the folders.
