Message 1 of 6
BT Cloud Desktop Client Failure – Blank Setup Window
A few days ago the BT Cloud Desktop Client window on my PC stopped displaying folders, navigation buttons and usage information - leaving just a blank screen. The PC is running Windows XP.
I have tried removing and reinstalling the Desktop Client several times, always with the same results: after accepting the licence terms I get a BT Cloud Login screen, but when the BT Cloud ID and password are entered the same login screen reappears. When ID and password are entered again, I get the message “Page expired - to protect privacy and improve security, the page you are trying to access is no longer available. Please, close the window and start over again”. Closing this window just takes me back to whatever was running before I started.
The process does apparently install the Desktop Client, as BT Cloud reappears in the Program List and an icon shows on the Desktop screen. But invoking the program just produces a blank window headed “BT Cloud Setup” with no options other than the usual minimise/resize/close buttons.
I have performed a system restore back to before the symptom showed up, and have tried the reinstall process both with different browsers running and with no browser, and with my anti-virus software disabled, all with the same result.
Any ideas?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT Cloud Desktop Client Failure – Blank Setup Window
Hi @jcdl and welcome.
It looks like you've tired everything at your side so if you're still having problems can you drop me over an email with the details and I'll lend a hand. You'll get the contact the moderators link in my profile.
Cheers
David
Message 3 of 6
Thanks - will do.
Message 4 of 6
Sorry David - I am logged in to the Community but your private contact details aren't appearing on your "About David M" page (although I see that other moderators' profiles are showing private contact details.)  Is this a privacy settings thing or is it something else I'm doing wrong?
Best wishes
John
Moderator
Moderator
Message 5 of 6
Hi @jcdl Sorry about that. I have enabled the link for you on my profile so you can contact us.
Cheers
John
Message 6 of 6
This problem was not solved until for entirely different reasons I bought and installed a new hub (BTHub6) to replace my existing Home Hub 2.0.  Cloud Desktop Client reinstalled immediately and seems to be working perfectly.
