DrPhoton
Message 1 of 2
BT Cloud - How to re-backup folders and files?
Hi, I have deleted my backup on the web interface to start a new clean backup again, but now BT Cloud is only backing up the new files. Is there a way to force BT Cloud to backup all files again?
I would appreciate any help. Thank you.
Tags (2)
1 REPLY 1
graystreet
Message 2 of 2
Re: BT Cloud - How to re-backup folders and files?
Personally, unless you're really desperate to back your files up to the BTCloud, I would wait until this mess is sorted out.
Reading the horror stories of people trying to back files up to the BTCloud, it taking forever, and then ultimately failing to back everything up would make me wary.
Once it is fixed, and I hope it is sooner rather than later, we don't know what the effect on existing cloud files will be. One would hope that they would not be affected but, after this fiasco, my confidence in BT to do anything sensible has taken something of a knock.
I'm currently using OneDrive and Googledrive. Once BT sort themselves out we'll see whether I use them again or not.
