JacquiT
Community Manager - Retired
Message 1 of 1
BT Cloud PC Client log in issue - Fix
An issue has been reported to us that for some BT Cloud customer's they are unable to use BT Cloud when upgrading their PC application.
The issue appears to have been caused by a certificate expiry issue which is normally resolved by running Windows Update.  However it appears this is not successfully updated in all cases – hence some people are affected and others not.
The certificate can be manually refreshed by completing the step below which will enable you to successfully log into BT Cloud again.
Step 1
Open your web browser and paste the link
https://a.mobify.com/bt/a.js
NOTE: This will present a BLANK webpage (this is deliberate)
Step 2
In the address bar – click on the padlock as highlighted in red
Step 3
Once clicked on the padlock a dropdown box is displayed
Step 4
Click on ‘View certificates’ and you will be presented with this
Once you have done that, this process is completed.
Validation Step
VALID FROM date is in the future and should be showing July 2014 or beyond.
It should now be possible to log into BT Cloud via the PC client again.
BTCare Moderation Team
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted Solution’.
