joebhoy
Message 1 of 6
BT Cloud Software
BT Cloud software really is slow. I have a 20Mb upload . it seems to take the same time for a 500k file or a 3mb file.
What would be better if you were able to map a drive to your storange and just use robocopy or a 3rd party tool.
5 REPLIES 5
DavidM
Moderator
Moderator
Message 2 of 6
Re: BT Cloud Software
Hi @joebhoy and thanks for posting.
How are you uploading the files? Is it via cable or wireless?
Cheers
David
joebhoy
Message 3 of 6
Its cable. Why would that matter ?
joebhoy
Message 4 of 6
It has finished teh backup. just took a long time, still, its done now.
Devon_Dave
Distinguished Guru
Message 5 of 6
What speed broadband are you getting?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
joebhoy
Message 6 of 6
20Mbs upload. All sorted now. Just need to find out the answer to my other Q in the forum about new files not being backed up.
