Message 1 of 3
BT Cloud Thanks
When I received the offer of an extra 500gb I thought that I'd try BT Cloud for backing up. The space is very generous but I find it unusable. I do not require automation because, having read the description, I find the synchronisation methodology employed unsafe (it has the potential to back up rubbish). I shall be sticking with my external USB drives for back up. I also tried the simple non-synchronised method but folders are not supported, its not compatible with MS Edge and the max file size is too small - I wanted to back up my mail (pst) files. What would be good would be the same space but presented as a  nework drive accessible via Explorer with the ability to create folder structures and a "drag and drop" facility. Let me know when ts done! Thanks
2 REPLIES 2
46
Message 2 of 3
Re: BT Cloud Thanks
.... nework .... I meant network ... sorry
srpsrp
Expert
Message 3 of 3
Re: BT Cloud Thanks
you can add folders in the backup section of the Mac desktop app, in theory at least. It doesn't seem to work reliably at the moment though ( see my other post)
