Message 1 of 1
BT Cloud Web Upload does not honour the current directory
BT Cloud used to work quite well, but since the skin and functionality changes, it is not so good.
I do not want to install the Windows App and have been uploading files to specified directories using the web interface. This used to work fine.
Now, if you create a directory or upload files, they all get put in the root directory meaning that you then have to 'move' them to where you want.
Does anyone know if there is a setting or a fix?
Tags (1)
