Message 531 of 1,226
Re: BT Cloud Won't Start
Everything is sorted, i have removed BT cloud from my machine and moved to One Drive.
Since removing it my laptop is working sooooooooo much better
Adios
Message 532 of 1,226
I wish I could do the same!.  I cant even download it all from the cloud unless I go into every single folder and even then cant download all files in that folder
How abut some-one loads all my files on a thumb drive and post it to me please - then you wont have to fix my issues!!!
I cant even get the desktop client to run AT ALL - let alone trying to synch any files
Message 533 of 1,226
jamieandangela, my message "What else is causing you concern ?" was sent to kc130a at the end of a successful discussion.
Before I begin, I am a user just like you and other than using there services, I have no contract with them, I'm only trying to help others where and when I can.  Moaning at me would only be an obstacle to this. so can you tell me exactly where version 20.6.1 starts to be problematic for you.
Message 534 of 1,226
Rogerdoger, re files not updating.  I have the same, with new files updating, amendments not.  The documents do not alter position in the list, it is not a case of 'missing the update' it simply does not occur.
BT are working on this particular issue and have called me run tests so they can look at the log files.
For the time being I am backing up any changes to a USB Flash Drive, just in case my laptop suddenly fails.  No hardship as I do not use BT Cloud for syncing across devices, just have to remember to do it.
Message 535 of 1,226
Just waiting for BT to issue a well thought out and thoroughly tested solution !!!!!!! LOL
Message 536 of 1,226
I cannot belive how this has all been screwed up since that last 'supposed ' update...what the hell are we supposed to do now??? Love the 'phrase 'sometime in the New Year'...NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!! Get it fixed....otherwise it's a complete waste of time 😞 JD x
Message 537 of 1,226
This is simply not 'good enough'....surely a large company such as BT can get their act together and sort this PC client problem out...we are paying for this supposed 'service' and we are not getting it...I shall seriously conside quitting BT altogether and change supplier for my landline.b/ban and mobile if this isn't sorted far more quickly than 'in the New Year'..it is franky, appalling. JD
Message 538 of 1,226
Is 'One Drive' the Google one??? Just had a mail from them saying that from 2021 (june?) if you are 'inactive' for a time and/or over-storage capacity...they'll 'clear out the files'...well...how bad is that????????????? Sheesh!
Message 539 of 1,226
Nothing has been backed up since 12th December, despite several stop / starts of the app.  This needs fixing ASAP.
Message 540 of 1,226
BT your update is otter **bleep** accept that......an update that needs to reload things shows just how poor it is I have never had an update that has meant data needs to be reloaded. Accept the fact the update is a total failure and remove it!!!!
We pay pays for a service so where is it!!!!
