Newbie
Message 1 of 2
BT Cloud and Macbook Time Machine Backup - Possible?
Hi guys,
Now BT has increased the free BT Cloud space from 50gb to 500gb for infinity customers, I'd like to back up my mac off site via time machine. I can't see an easy way to do this. Is it possible?
I can do a time machine backup to my Synlogy NAS but the macbook Bt Cloud Sync folder is on the mac. Obviously I can't backup time machine onto my macbook drive as there isn't space. Is there a way of moving this folder to the Synology NAS? (then I could do a time machine backup to that folder).
I know on a PC you could use mklink to create a hard link to a NAS in the Bt Cloud Sync folder (and so put a hard link to a time machine backup in the Bt Cloud Sync folder). However can this be done on a mac?
Thanks for the help.
1 REPLY 1
Expert
Message 2 of 2
Re: BT Cloud and Macbook Time Machine Backup - Possible?
Can't see any way to do this either. Don't think it's possible. Only way would be to link your home (user) folder to BT Cloud, under settings I think.
