Message 11 of 23
Re: BT Cloud delete version history not working
Matt
No, as a case had already been raised.
Message 12 of 23
Matt-S
What's the no. for the Cloud Help Desk, please (I can't find it anywhere).
I have this problem too, and was forced to buy extra memory.
Eddie J
Message 13 of 23
Hi @edxw I'm sorry you're experiencing issues with your BT Cloud service. You'd be best sending them an email to btcloud.support@bt.com include your BT account details and description of the fault and they'll be able to get that looked into.
Message 14 of 23
Thanks NeilO
I did in fact email btcloud.support@bt.com some days ago and haven't heard anything yet.  Perhaps I should try again with my BT account details.
Eddie J
Message 15 of 23
@edxw,
It may take the BT Cloud team a few days to get back to you as they are really busy. If you have not included your account information in your first email it would be best to email them again and include this information.
Matt
Message 16 of 23
Received a call today from the BT Moderator to say the issue had been fixed and having run some tests it does appear to be functioning correctly and new backups are currently running. It has taken some time to resolve but BT Cloud Backup is working again with no need to buy extra space. Pleased with the end result, many thanks.
Message 17 of 23
Unfortunately it's not working for me - still getting the same 'Purge version history call failed!' message. It shows a massive 345Gb for Versions history (nearly all of the total usage of 347Gb) so perhaps that's contributing to the problem?
Haven't had a reply to my email of weeks ago and have not pursued as I've been preoccupied with other matters.  (I've stopped using BT Cloud and made use of OneDrive in the meantime for backups etc.). I'll have to see where I go from here - might just leave BT after many, many years as  a customer ( and former employee).
Message 18 of 23
I am in the same boat. 3 months and BT cannot find someone with enough nous to fix this
Message 19 of 23
Well, well! A couple of hours ago my usage cleared suddenly, with nothing shown for Versions history.  I've reinstated my backup folders and all seems to be OK.
Of course, it's early days ...
Message 20 of 23
A new version of software and Delete files and Delete version History still not working. Hopefully one day BT will get this fixed!!
