DJFulford48
Message 1 of 3
BT Cloud on Android
Where is the BT Cloud synced folder on an Android (Kit-Kat 4.4.2)?
I loaded the BT Cloud app onto my Sansung Galaxcy S4, but it took a long time to log in. I just had to put the phone down a do something else while it located my account. It now seems to work.
Now I would like to include BT Cloud on the list of sites I can access through Astro file manager with Cloud. It can log into Dropbox and Skydrive (which I am not using), but not BT Cloud.
2 REPLIES 2
DavidM
Moderator
Moderator
Message 2 of 3
Re: BT Cloud on Android
Hi DJFulford48,
Welcome and thanks for posting. The Sync folder is not displayed separately as a ‘local’ folder as it is on PC/Desktop, but it’s simply accessible through the app by clicking on BT Cloud Sync in the left hand menu.
Cheers
David
Writerman
Message 3 of 3
[quote]The Sync folder is not displayed separately as a ‘local’ folder as it is on PC/Desktop, but it’s simply accessible through the app by clicking on BT Cloud Sync in the left hand menu.[end-quote]
That's all very well if all you want to do is view the file on your phone. What I don't understand is how it works if you want to use your Android device to edit a shared file.
For example, I have several Word documents containing works in progress. When I edit a document on my PC, all I have to do is save the edited version to the Sync folder in order to be able to view the latest edited version on my Android phone.
How do I do it the other way round, though? Suppose I edit the document on my phone (yes, I really do write books on my phone!). Where do I instruct my Android-based word processor to save the revised file so that the cloud version gets updated so that I can subsequently access it on my PC? I tried doing a straight "save" (as opposed to "save as") but the updated version doesn't get copied to the cloud.
The only way I have found is to keep deleting the document from the cloud and then re-adding it. That's clunky, a real hassle, and cannot surely be the design intent.
Kind regards
Keith Sheppard (author).
