Message 1 of 2
BT Cloud search facility
For as long as I can remember a Search has almost invariably failed with the usual "technical problems" message.
Today, for the first time that I can recall, four consecutive searches worked, presumably as a result of their rebuilding the metadata after the "upgrade".
If a reliable Search facility is part of the so-called "upgrade" (which should mean "improvement", of course) then  at least they've done something useful.
One minor annoyance remains in that there are four options to choose from, only one of which ("Documents") finds the required directories, but I can live with that.
1 REPLY 1
Message 2 of 2
Re: BT Cloud search facility
("Documents") to read ("Other")
