spoontea
Message 1 of 6
BT DNS again not working correctly
again BT DNS server not working correctly. Some of the websites not openig.
To get all you website opening you need to change the DNS settings.
I'm using opendns 208.67.222.222 and 208.67.220.220
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: BT DNS again not working correctly
It's working fine for me.  When I've had problems, I can usually fix it by rebooting both the Home Hub and the PC.
NewtronStar
Expert
Message 3 of 6
Don't forget to go back to BT DNS server (Automatic) in case the DNS your using at the moment stops working correctly in the future Smiley Happy
spoontea
Message 4 of 6
I reset all my pc, hub and open reach modem before I post here.
It's standard procedure I do when I have internet issues.
It wasn't working correct;y for about 45 min when I've change my DNS settings. Then I've checkied it again about 1h later, was still same.
When I checked it about 3h after initial broblem discovert it was all working fine.
Me and my frined we noticed that BT DNS server is playing up on regular basis 1-2 times a month.
Typical it's for about 20-30 min then is back to normal (unless it's like about 1h ago when it was f***ed for 2-3 days).
Distinguished Expert
Message 5 of 6
I can't see the point of going back to BT DNS server (Automatic).
You're better off leaving it set to ones that are working rather than going back to ones known to be flaky
To say thanks for a helpful answer, please click the white star
Sage
Message 6 of 6
Why use BT's DNS servers at all? It is totally unnecessary. You don't need openDNS as your secondary server.
You could have OpenDNS as primary and Google as secondary or visa versa.
