Angelface
Message 1 of 2
BT Decor 1200 Help!
I have a new Decor 1200 which keeps ringing out with a long tone whilst displaying an "incoming call".  When I answer there is noone there. None of my other extensions ring.  I can get a dialling tone and make calls, but I can't keep the phone plugged in because it continually makes this ringing tone every 30 seconds or so.  There are two other extensions on the same line which seem to work OK and three SKY extensions connected to a TV which are very rarely used. Could these be causing a problem?  And do the TV extensions affect the REN rating?
It really is driving me mad, can anyone help?
1 REPLY 1
Moderator-Retired
Message 2 of 2
Re: BT Decor 1200 Help!
Hi Angelface,
Have you tried the phone on any of the other extensions, or at your master/test socket yet?
Cheers,
Chris
BT Moderator Team.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
