keithp
Message 1 of 14
BT Desktop Help - new version update
Hello
Over the past few days each time I log on the BT Desktop Herlp program says there is a new version. I click update, it says new version installed ok. I go to the help program - it says newer version available, I click to install, it installs, I open the help program, It says new version available.......you get the picture.
Any idea how to stop it showing new version available? Ic an't find an options at all.
Keith
13 REPLIES 13
maglin
Message 2 of 14
Re: BT Desktop Help - new version update
Have a look at this thread - dml seems to have beenm given a solution.
http://community.bt.com/t5/Other-BB-Queries/Desktop-Help/td-p/419055
Distinguished Guru
Distinguished Guru
Message 3 of 14
Have you tried uninstalling and reinstalling it from scratch?
Or maybe that should be uninstalling and leaving it uninstalled; the general advice on these forums is that BT Desktop Help is more trouble than it's worth.
DarrenB
Message 4 of 14
@keithp wrote:
Hello
Keith
Hi,
Can you right-click the Desktop Help Icon in the system tray (white ? in a black box) and select "Service Tag".
in the bottom left-hand corner in Grey text can you tell me what the version number is. Should be in a format like 12.08.01.01C
Also what OS are you usiing, XP or Win 7?
keithp
Message 5 of 14
It is:
12.07.01.02C
OS Win 7.
Keith
DarrenB
Message 6 of 14
@keithp wrote:
It is:
12.07.01.02C
OS Win 7.
Keith
It looks like the update never completed as the current version is 12.08.01.01C.
Do you run your PC in a user account rather than an admin account?
keithp
Message 7 of 14
Only two accounts created - both with admn rights.
So no idea why its dodnt work!
Keith
Message 8 of 14
Don't use it to be honest. It's less than useless.
the-exile
Newbie
Message 9 of 14
Keith,
Sorry no help to you but mine does the same, drives me round the bend after a while, my version stuck on 12.07.01.02C
using win 7
DarrenB
Message 10 of 14
Are you confident enough to look in the registry for me at the following location?
HKEY_LOCAL_MACHINE\SOFTWARE\Motive\Rainier\btbb\InstalledBundles
If happy could you paste the values for all the entries:
AGB
AXB
AXB64 (if you have a 64bit client)
CDB
OCB
