Message 1 of 2
BT Email - Error 800ccc0f
At various times of day (particularly morning) and nearly every day when I go to sync outlook with BT mail I get the following error:
Your IMAP command could not be sent to the server, due to non-network errors. This could, for example, indicate a lack of memory on your system.
Configuration:
Account: BT Email
Server: mail.btinternet.com
User name: robhunt54@btinternet.com
Protocol: IMAP
Port: 993
Secure(SSL): 1
Code: 800ccc0f
When I then try to check what is happening on Webmail I login and it comes up with the following error:
Selected account BT Mail Account is unavailable
This only happens on my primary account all other accounts are fine. And it does not happen all the time.
Any thoughts?
Rob
1 REPLY 1
Message 2 of 2
Re: BT Email - Error 800ccc0f
Same error here. Quite often (once an hour). Our broadband connection is sluggish (2MB at best).  Could this be an IMAP sync error?
   Protocol: IMAP
   Port: 993
   Secure(SSL): 1
   Code: 800ccc0f
Windows Live Mail says "Setting Message Flag" and then TCP/IP connection lost.
