Message 1 of 3
BT Email and IMAP stopped working
Hi
This morning IMAP stopped working with my BT email account.  I have tried several email clients on PC and Android but none of them work and they behave like I have entered an incorrect email or password.  I have checked my password is correct and can log in to webmail without issues.  I am using the mail.btinternet.com server information and SSL encryption settings as per the instructions but I still cannot get it to work.
I contacted BT through Twitter and, rather unhelpfully, was told that they cannot provide support for third party applications even though I am fairly sure the problem is with BT.  I have never had any issue with other mail providers but BT seem particularly unreliable and unhelpful.
Can anyone help?
Ross
2 REPLIES 2
Message 2 of 3
Re: BT Email and IMAP stopped working
Unfortunately, it's a very common problem that usually resolves itself in a day or two. Don't make any changes to your settings.
Tags (3)
Message 3 of 3
Hi
Thank you for the reply - indeed everything did start working again after a day.
Ross
