Message 1 of 12
BT Exchange to Home is 79.8Mb - Home to Laptop is 75.2Mb
Why am I not getting the 79.8Mb? I have turned off the WiFi on my BT Home Hub 3 Type A and my laptop that is very fast is the only one plugged into the Hubs Ethernet port 1.
BT Speed Test
11 REPLIES 11
Message 2 of 12
Re: BT Exchange to Home is 79.8Mb - Home to Laptop is 75.2Mb
Turning off the wireless settings wont free up the bit of you Infinity that's available as public wifi. Even if you opt out of the free wifi you wont get all the bandwidth to use.
Message 3 of 12
The 79.8 mb is your maximum attainable speed your line can support you will never achieve that the 75.2mb you are getting at your laptop is correct and is an excellent connection nothing is wrong just enjoy it
Message 4 of 12
Is there a reason why i dont get the max speed seein as my line can support it?
Im very happy with my download speed but ok about my upload seeing as its meant to be 20Mb.
Message 5 of 12
yes the reason is the operating overheads with your connection speed i would expect your IP Profile to be 77.43mb and your download speed cannot exceed that
Message 6 of 12
why is everyone's profile being limited to 77.43mb?
there has to be an explanation for that?
Distinguished Guru
Message 7 of 12
Your IP profile is set to 96.8% of your sync speed.
If not, I'll try again 🙂
Message 8 of 12
ok so my ip speed is 79.8mb and my actal speed is the other one?
Distinguished Guru
Message 9 of 12
Confusion sorry, your sync speed is 79.8, your IP profile is 77.43 and your actual download speed is 75.2
Message 10 of 12
What ever these guys say, I simply don't believe it anymore. False information, and they keep repeating each other.
More here:
http://community.bt.com/t5/BT-Infinity/Who-can-explain-this-No-Solution-required/td-p/872132
