Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi,
I'm having some issues getting Sophos Home UTM OS to work with BT Infinity (fibre to the cabinet)
I'm not sure what the Wan Uplink settings should be for BT Infinity (fibre to the cabinet) can anyone help?
Nicholas
Try ticking VDSL and entering homehub@btbroadband.com as the username and BT as the password.
Thanks for your reply. Unfortunatly it doesn't seem to be working.
Dare I guess VLAN Tag is same as VLAN Id?
Assuming it is try 101 in there.
Yep, missed that.
Nope 😞
You seem to have unticked IPv4 default gateway between screenshots.
Failing IPv4 suggestion working is this any help?
http://techbast.com/2015/03/perform-a-basic-configuration-sophos-utm-in-12-simple-steps.html
What does the IPv4 default gateway setting do?
I'll take a look, thanks
