licquorice
Message 11 of 14
Re: BT FTTC - Sophos Home UTM WAN Uplink
I presume you are connecting to an Openreach modem, if so what other connection types are shown in the dropdown. DSL is probably incorrect. Is there a plain PPPoE?
Edit: There doesn't appear to be a box to set authentication type for the PPP session.
Liam_
Recognised Expert
Message 12 of 14
@licquorice
This looks like the kind of thing you need to download and play with.  Mind you it takes up more space than a separate modem and router screwed to the lounge wall.
The wife would love a PC sitting next to the master socket.
nich5
Message 13 of 14
I've tried everything suggested here but unfortunatly no luck 😞 I'm using a BT Home Hub 5.
Has anyone here had any luck using Sophos UTM Home with a BT Infinity Internet connection?
Also just checking clients that should have content controlled by the UTM don't have to be plugged in through the UTM do they? As long as the clients are connected with the same LAN with the same subnet etc it should be fine? As I say this is the first time ever that I've tried to implement an advanced network security system.
licquorice
Message 14 of 14
May I politely suggest that the Sophos system is not for beginners and that built in firewalls are usually perfectly adequate. I would suggest posting on their forum (if they have one) for further advice.
