Message 1 of 5
BT FTTP + Smart Switch (TP LINK TL-SG105E) + Nest Wifi
Hi
Hope you are well.
I've just had BT Engineers install a new ONT inside my house and set up the FTTP fibre (current connected to Smart Hub 2).
I was previously using Nest Wifi + mesh system.
I want to disconnect the Smart Hub 2 and use the Nest.
Please can I get some assistance (complete novice so a Dummy's guide would be useful).
From the ONT - which port on the switch to I connect the ethernet cable.
From the Switch - which port on the switch (1-5) and on the nest puck do I connect the ethernet cable to (globe or two arrows).
Once i've done this bit what should happen next? and if the above does not work how do I go about testing/fixing
Many thanks,
Mo
4 REPLIES 4
Message 2 of 5
Re: BT FTTP + Smart Switch (TP LINK TL-SG105E) + Nest Wifi
@iamwhatiammo wrote:
Hi
Hope you are well.
Any, but you can just use the one that you used to connect to your previous modem.
Whichever it was connected to before. I suspect the globe is a dsl port and the 2 arrows are an Ethernet port
If you were previously with BT, nothing, it should now work. If not with BT you will need to enter the generic PPPoE username of [email protected] and password BT on the Nest wifi
Many thanks,
Mo
Message 3 of 5
I'm cracking up, only just realised what you are doing. Why are you using a switch between the ONT and the Nest, it won't serve any purpose. Just connect the ONT to the Nest WAN port.
Message 4 of 5
Hi Thanks for the quick response.
When I connect the Nest direct to ONT - all seems to work fine.
But when I connect the switch in between the ONT and Nest ( ONT - SWITCH - NEST) I'm getting no connection.
I'm assuming I need to configure the switch?
If so, can you advise how I can do this?
I've installed the TP Link Utility - which has identified the Switch when connected via ethernet to laptop and nest puck.
When I open this up, there is a whole load of configurations I can make from system, switching and including VLAN.
VLAN has 4 options: MTU, Port based, 802.1Q VLAN, 802.1Q PVID.
No idea what I'm doing here at all now
Thanks again
Message 5 of 5
Oh lord!! Yepp, works this way.
BT Engineer told me this wouldn't work so went out and bought a smart switch.
Thanks for clarifying this redundant purchase
