louisoft01
Message 1 of 11
BT Faster Broadband Speed Getting Slower Over Time
So I had what BT calls unlimited "faster" broadband since november.
Its long distance FTTC basicly.
I have noticed the speed has dropped over time.
When I had the service installed i was achiving about 17Mbit down and 1.8mbit up.
Now I have got 11mbit down 900kbit up.
BRAS Profile
The current Downstream BRAS rate is: 11.6 Mbps
The current Upstream BRAS rate is: 2 Mbpssyncspeed.PNG
6. Data rate:944 / 11990
7. Maximum data rate:1177 / 12665
8. Noise margin:6.8 / 6.1
9. Line attenuation:14.1 / 31.0
10. Signal attenuation:14.1 / 25.1
Should I bother calling to get a engineer to come out.
10 REPLIES 10
john46
Message 2 of 11
Re: BT Faster Broadband Speed Getting Slower Over Time
the stats show no problems an engineer visit would achieve nothing
imjolly
Message 3 of 11
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
your stats look ok
louisoft01
Message 4 of 11
your stats look ok
VDSL Range A (Clean)19.313.11.80.8--Available----
VDSL Range B (Impacted)155.21.60.6--Available----
ADSL MaxUp to 3--2 to 5.5Available----
Fixed Rate1----Available----
VDSL Multicast------Available----
imjolly
Message 5 of 11
your current connection speed is just below the bottom estimated speed
are you using the test socket with a new filter to eliminate your setup and internal wiring from causing a problem
louisoft01
Message 6 of 11
Tried that just now, only a slight improvement
Sync Speeds
Downstream: 12.46 Mbps
Upstream: 941 Kbps
imjolly
Message 7 of 11
can you post the same stats as before now you are using test socket
louisoft01
Message 8 of 11
stats when in the test socket
6. Data rate:941 / 12755
7. Maximum data rate:1173 / 13628
8. Noise margin:6.6 / 6.1
14.1 / 25.2
PS I have also disconected the one extension I have from the socket to see if it helps when i go back to the regular socket.
Message 9 of 11
Still just below, Openreach engineer visit required then.
louisoft01
Message 10 of 11
booked engineer.
