Message 1 of 6
BT Fibre 1 capped at 40/10
I got BT Fibre 1 because I knew my line could support the 55/10 profile  but it looks like it has been set up wrong.
if i wanted to be capped at 40/10 i would have got the cheaper essentials package.
How can this be uncapped so my line can sync at the correct speed,  which if the 3db profile kicks in would be close to 55.
Line Stats
Spoiler
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    1
Last initialization procedure status:   0
Max:    Upstream rate = 7309 Kbps, Downstream rate = 42323 Kbps
Bearer: 0, Upstream rate = 7309 Kbps, Downstream rate = 39999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        7.0             5.9
Attn(dB):        24.9            0.0
Pwr(dBm):        13.3            5.3
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              166             223
M:              1               1
T:              0               37
R:              10              16
S:              0.0000          0.9731
L:              10668           1973
😧              16              1
I:              177             120
N:              177             240
Q:              16              0
V:              5               0
RxQueue:                24              0
TxQueue:                8               0
G.INP Framing:          18              0
G.INP lookback:         8               0
RRC bits:               0               24
                        Bearer 1
MSGc:           90              -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              10.6667         0.0000
L:              24              0
😧              1               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               471766
OHFErr:         0               172
RS:             1103735952              438535
RSCorr:         77447           5059
RSUnCorr:       0               0
                        Bearer 1
OHF:            20104342                0
OHFErr:         0               0
RS:             120625681               0
RSCorr:         398             0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         10712           0
rtx_c:          10209           0
rtx_uc:         17836           0
                        G.INP Counters
LEFTRS:         80              0
minEFTR:        40014           0
errFreeBits:    328490468               0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    3365062427              0
Data Cells:     1868601228              0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             11              447
SES:            11              0
UAS:            66              55
AS:             323015
                        Bearer 0
INP:            48.00           0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            0.00            9.03
OR:             0.01            28.32
AgR:            40104.49        7337.20
                        Bearer 1
INP:            2.50            0.00
INPRein:        2.50            0.00
delay:          0               0
PER:            16.06           0.01
OR:             47.81           0.01
AgR:            47.81   0.01
Bitswap:        29455/29455             27595/27595
Total time = 4 days 23 hours 42 min 4 sec
FEC:            112393          6514
CRC:            557             468
ES:             11              447
SES:            11              0
UAS:            66              55
LOS:            1               0
LOF:            7               0
LOM:            0               0
Latest 15 minutes time = 12 min 4 sec
FEC:            64              23
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            85              30
CRC:            0               2
ES:             0               2
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Latest 1 day time = 23 hours 42 min 4 sec
FEC:            21275           554
CRC:            0               37
ES:             0               34
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Previous 1 day time = 24 hours 0 sec
FEC:            23163           3534
CRC:            0               32
ES:             0               28
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Since Link time = 3 days 17 hours 43 min 33 sec
FEC:            77447           5059
CRC:            0               172
ES:             0               156
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
5 REPLIES 5
Message 2 of 6
Re: BT Fibre 1 capped at 40/10
According to stats posted your max attainable connection speed is only 42mb and this is not affected by your package choice
enter your phone number and post results remember delete number but leave exchange and cab
Message 3 of 6
South Elmsall Cabinet 16
VDSL Range A (Clean)
VDSL Range B (Impacted)
52.435106.932.4AvailableAvailable
51.635106.630AvailableAvailable
As the snr is at 7db and sync at 39999 it seems rather obvious to me that the line has been provisioned at 40/10 instead of 55/10.
The line attainable is 42 with a target SNR of 6db, with g.inp and the 3db snr the line should be close to 55.
Message 4 of 6
Except you are on an ECI cab so no G.INP.
Message 5 of 6
There are multiple cabinets at that pcp.....
The line is on a huawei cabinet, as shown by g.inp already being active.
Also in the stats elsewhere it shows a broadcom chipset.
Message 6 of 6
So do I just get ripped off or how do I get the correct profile applied?
I mean surely I'm dragging down the 50mbit average that BT advertise.
Surely if i'm sold Fibre one apply the 55/10 profile not 40/10, it costs more than fibre essentials and I got it for the 55/10 profile.
