Message 1 of 3
BT Fibre 900 log cabin
Hi I have fibre 900 with BT. I was wondering I have a log cabin and  signal is weak   up the signal with current Wi-fi 6 router ASUS AX88u. What suggestion would you recommend to reach the cabin Extender or powerline/Mesh to have a better signal in cabin.?
Tags (3)
2 REPLIES 2
Message 2 of 3
Re: BT Fibre 900 log cabin
Run ethernet and add an acess point.
Message 3 of 3
@tomhumph97
Ethernet cable is the sure way to access full speed in your cabin Tom.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
