Distinguished Guru
Message 81 of 97
Re: BT Fon access problems
Shows how one would expect - Unsecured network
Spooky goings on....Smiley Very Happy
(I'll dump inSSIDer and d/load it again)
-+-No longer a forum member-+-
syops
Recognised Expert
Message 82 of 97
I imagine its a reporting bug in the main display, showing your SSID info with the Openzone name, seems inSSIDer struggles with a router broadcasting more than two SSID's.
On mine FON shows with its own colour, but Openzone and my SSID show under the same line and colour. Smiley Indifferent
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. 🙂 ***
syops
Recognised Expert
Message 83 of 97
Just a thought, this may be a cause of some of the problems with the Openzone hotpsot if it is actually transmitting the same mac address as our own SSID?
FON shows a different mac address
Actually a fault with inSSIDer, I just got the latest version 2.0.7.0.126 whoops! 2.0.7.0.128.. Works fine now, all seperated out and on different MAC address'
Distinguished Guru
Message 84 of 97
Hmm, I've also downloaded the latest inSSIDer (version 2.0.7.0.126)
And I've also been running an application that comes pre installed on the Laptop
And I've been observing very odd behaviour
(top image highlighted in green (by inssider) is my hub which then jumps to BTOz and back to mine)
(using the pre installed radar - images above)
My SSID transmitting on g
Fon on n
BTOz transmitting on n BUT with same MAC as my SSID throughout
Then mine on n
others on g
Then Fon on g
others on n
Then Oz on g
Others on n
All on g
So far not noticed all 3 on n
syops
Recognised Expert
Message 85 of 97
Ah I see what I have done, whoops my version is 2.0.7.0.128.
has the fix for the above
clicky
http://www.metageek.net/forums/showthread.php?4172-Problem-with-2-Ap&p=14887#post14887
Malacath
Expert
Message 86 of 97
@falkirk81 wrote:
I am on holiday and got my laptop with me. I have a BT Fon signal nearby with an 'excellent' signal strength. Trying to connect to either the BT Fon or BT Openzone results in the 'limited or no connectivity' message.
I have tried everything with my laptop, but it works fine at home on my BT Home Hub so I do not think it is my laptop.
Also, strangely enough, my iPhone connects up without issue to the BT Fon point when using the new iPhone app.
Any ideas on whats going on?
Steven
Same here. BTFON doesn't work on my Acer laptop and HP laptop. But works fine on a Toshiba laptop.
The Acer Laptop and the HP laptop both have Atheros wireless adaptors. The toshiba has intel.
Is anyone elso who can't connect to Fon using a laptop with an Atheros adaptor?
Distinguished Guru
Message 87 of 97
@syops wrote:
This post is brought to you via CISCO VPN and BT Openzone 🙂
Same hereSmiley Happy
So VPN seems to work, hard to tell in an external kind of way, but seems to report all ok 🙂
I've only connected to my BTOz connection so far....
Had to enter the download file address directly, not just its parent page. Btopenzone dot com still not accessible via FON or Openzone connnections.
+1Smiley Mad
Note to BT - imho you really need to look into this...
                  if you already knew about this, it would of been nice to be told
syops
Recognised Expert
Message 88 of 97
Good to know 🙂
Yeah I have only used my own connection so far.
You got the latest version of inSSIDer? .128 Should show the networks properly, although fon and Openzone keep showing regular power drops 😞
Distinguished Guru
Message 89 of 97
I clicked the link you gave and then tried the zip...
as it needs registering to d/load it, I've not done this so I'm still on .126
(I'd guess that .128 is a test version - then they'll release it)
Still to see my SSID, FON and Oz all on band n.....
syops
Recognised Expert
Message 90 of 97
FON and Oz are N on mine, while my SSID is g but thats because my adpater doesn't support N. Imagine if I knocked it back to b/g only they would come back to g. (might try it)
tried it, still broadcast n even though b/g only on settings 😞
yeah .128 isn't a release build yet
