jossman
Message 1 of 5
BT Fon and BT Openzone questions
Hi,
I have recently opted in to BT Fon.  I don't have a Home Hub (need a more powerful router) so does this mean I will not be sharing my connection (or does BT change my router on the sly)?
Regarding Openzone, what username should I use (it isn't obvious), because my BT Infinity (opt 2) package apparently comes with Openzone access.
Thanks in advance!
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: BT Fon and BT Openzone questions
Yes - you won't be sharing
BT can do whatever they like to their supplied hubs only....
AFAIK it's still the primary email account holders name and password - as per using FON
-+-No longer a forum member-+-
Message 3 of 5
In addition to DS comments, in the BTOZ landing page, sign in as a BT broadband customer on the drop down menu.
AQ.
"Welcome to Royston Vasey - You'll never leave."
jossman
Message 4 of 5
Many thanks for both your replies. Is there anyway for users with OZ access via TB/Infinity to access Openzone via intermediaries such as Boingo (who operate in BAA airports) and have an OZ option in thier login? My user details don't appear to work...
Thanks in advance!
Distinguished Guru
Message 5 of 5
As AQ mentioned, you need to sign in as a BT customer - I'd say if Boingo don't have this option, then you can't use it.
Other forum members may know for sure...
