gme
Message 1 of 11
BT Fon and BT WifiX opt-out
Hello - I'm opted out of BT FON and BT Wifi X but I've just dicovered that my status is active and my hub is still broadcasting a BT Fon and Wifi X signal. How can I get my hub to go non-active? I had this problem once before and finally did get it to go non-active, but then we moved and apparently the problem has started all over again. Many thanks!
10 REPLIES 10
Jaseb41
Message 2 of 11
Re: BT Fon and BT WifiX opt-out
I'm having the same problem too, I've got hub6 and opted out via BT fon web page within 48 hours it was switched off brilliant! About a week ago got the new 316 update so I did a factory reset after the update to make sure it was configured properly but unfortunately after doing so it reactivated BT wifi/fin do again went to the same web page https://www.bt.com/wifi/secure/index.do?s_cid=con_FURL_btfon it said I was opted out already but I opted out again which it said would be deactivated within 48 hours but it hasn't so after the 48 hours I did this again but yet again it is still active and won't switch off, I'm just wondering if the new 316 update is somehow blocking or not receiving the command to deactivate BT wifi ?
Dippu
Expert
Message 3 of 11
If Factory Reset is done then the hub will activate BT Fon since it is a default setting. To opt out again you may need to opt in first and then opt out, regardless to what the BT WiFi page says
Liam_
Recognised Expert
Message 4 of 11
Something else that should be 'Opt In' instead of default.
gme
Message 5 of 11
After one useless chat and several phone calls to people at the tech help department who did not understand the problem even after I explained it several times, I finally got someone at that department who not only understood the problem, but discovered why I'm having it. The only problem is that he said that it can take up to 10 days for one department to do something in my account and then a further four weeks for the tech people to actually turn off the BT Wifi signal from my hub. Honestly, I do not understand why it will take over a month to do something that I ought to be able to do from my hub in 15 seconds. If anyone can tell me how to get rid of BT Wifi in a shorter time, all suggestions welcome. (I've already thought of switching to another provider, so that one's taken. Sorry! 🙂 )  Many thanks!
licquorice
Message 6 of 11
Its not just a question of turning off the signal on your hub, its also removing your account to enable you to connect to hotspots.
Liam_
Recognised Expert
Message 7 of 11
Buy a third party VDSL router.  No more fon/wifix or whatever.
john46
Message 8 of 11
It is default on as it is part of the contract and has been for many years  being able to turn it off at the hub would not stop the user being able to use the BT Wi-Fi when out and about
Dippu
Expert
Message 9 of 11
@gme try my suggestion
gme
Message 10 of 11
A third-party router sounds like an excellent solution. Not being a tech person myself (degree in history - need I say more?), I assumed that if BT is my provider, I've got to use the hub BT sent me. A router from an independent firm would solve the problem quickly and permanently, so the cost of the router is of no concern. Thanks very much for the suggestion - I'll consider the problem resolved.
