Message 1 of 3
BT Fon
I opted out of BT Fon and I think its been the required 48hrs but it's still showing active. I thought I'd dp it before I swapped out the Homehub 3 for my new router. Is this necessay or will BT Fon automatically not work with a non BT router?
2 REPLIES 2
Message 2 of 3
Re: BT Fon
BTFON/BTWIFI will not work on a non bt router - as long as you remain opted in to BTFON/WIFI then you can still access when you are out and about - that is ok
Guru
Guru
Message 3 of 3
Re: BT Fon
Hi rattyjunk,
The BTWifi SSIDs (BTFon/BTOpenzone) shouldn't be broadcasted from a third party router, as the BT HomeHubs are made to accept a config file which is updated by TR-069 remote management as well as designed to transmitt the BTWifi (Fon/Openzone) public SSIDs.
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
