Message 1 of 3
BT Full Fibre 900 with Draytek 2862ac
I've just upgraded from BT Fibre 300 to BT Full Fibre 900. I am using a Draytek 2862ac router (broadband on WAN2) and this worked fine, getting around 300Mbs.
However. after the upgrade to 900Mbs, the Draytek is only getting around 380Mbs. The Business Smart Hub  2 gets the full  900+Mbs but I would like to remain with the Draytek.  Any ideas on improving the Draytek performance?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: BT Full Fibre 900 with Draytek 2862ac
You will need to buy a new router - that model is only rated up to 400Mb/s for the firewall:
https://www.draytek.co.uk/products/business/vigor-2862#specifications
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 3 of 3
Thanks I had a feeling that would be the case
