So does G.INP only work on the Hauwei modems at the moment and all ECI modems have to have a firmware update? Should I replace my ECI modem with my HG612 even though my cabinet is eci, I mean everyone seems to be saying how superior the HG612 is because it has a broadcom chipset and doesn't need a firmware update for g.inp
Myself and others on the unlocked thread found the eci/r a little better than the hg612.*
Also my ECI green street box was upgraded a few weeks ago (with new tech bits I think) and the my unlocked eci/r is working great with higher speeds and in "Fast" mode.
Quick type of the stats
ActualInterleaveDelay=0 ActualImpulseNoiseProtection=0 nINTLVDEPTH=1 DataPath = Fast
I also believe g.imp is just a broadcom name for the new bt transmisson technology.? There is a good thread on thinkbroadband about it.
The ECI/r and both hh5's support bt's new transmission when I asked.
*From the unlocked thread:
Other posters also reported the same from earlier in the thread.
can confirm the ECI runs MUCH cooler than the HG612.
I swapped my HG612-3b for an ECI and can confirm it runs far cooler. It barely gets warm to the touch. The ECI also has slightly better latency than the 612.
latency shows a greater increase when using the HG612 when compared to the ECI
The heat mats worked a treat on mine as the walls were recently re plastered {getting the drill out wasn't really an option... quiet life et-al
Maybe the heat was more noticeable due to the way I had the hg612 3b set up ? Do find the eci/r much cooler in the same set up configuration.
Hi, I don't have an ECI modem, but G-INP on my H216 was enabled 3 days ago without a firmware upgrade. My modem is unlocked and the connection speed has increased by 4Mbps. I noticed that interleave has also been enable at level 8 (DL). My cabinet is in Maidenhead.
There’s lots of confusion out there as to how to tell if your line is G.INP enabled.
You may find this article by Mark Heath of interest :- http://www.increasebroadbandspeed.co.uk/g.inp
Things are moving quite quickly on this so he will update the article as he gets more information.
I have a BT HH5, any way of knowing if it's enabeld on it?
So far, everyone that i have seen post that they have G.INP enabled are on a Hauwei cabinet. I have seen no reports of this being enabled on an ECI cab.
Has anyone on an ECI cabinet had G.INP enabled?
Is there a way to tell if its on from the BT HH 5 type B?
There is so much incorrect information taken from a single post on Kitz 😞
