StuartJC
Newbie
Message 1 of 3
BT Graphite 1500
I have bought a BT Graphite 1500 - is this a new model??
The main question - can I adjust the volume of the handset for incoming calls?
I hope someone can help.
Stuart
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: BT Graphite 1500
Hi and welcome.
Yes the Graphite is still a current model supplied by BT, have a check here in the user guide.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
StuartJC
Newbie
Message 3 of 3
Thanks Dave for your response.
The main question - can I adjust the handset volume?
Regards
Staurt
