Recognised Expert
Message 11 of 35
Re: BT HD channels missing & slow speed via powerline
what model PLAs are you using for BTTV? Netflix, iPlayer Films etc. apps doesn't use Multicast they just needs an Internet connection to stream.
Message 12 of 35
They are TP link AV600 type. Pass through ones have a socket on. Are these compatible?
Recognised Expert
Message 13 of 35
The Datasheet states: Supports IGMP managed multicast IP transmission, optimizing IPTV streaming so don't see why they shouldn't work
Recognised Expert
Message 14 of 35
Although when you look at the individual PLA TL-PA4020P, which is one within the kit, it doesn't mention Multicast??
Message 15 of 35
It's these, AV500 sorry
http://uk.tp-link.com/products/details/cat-18_TL-PA4020-KIT.html
So if they do support then I'm stuck again on what to do...
Message 16 of 35
Also have these in the house
http://uk.tp-link.com/products/details/TL-PA451KIT.html
So now I'm unsure if these work or not then. So you definitely need Multicast PowerLine adapters for the BT TV box?
I take it the BT branded ones definitely do, how can we tell? What exactly am I looking for?
Recognised Expert
Message 17 of 35
Broadband Extender 600 Kit or Broadband Extender 600 Flex are what BT supply now, if you've recently ordered BTTV you should be able to request the 600 kit for £20 but if you need the 600 Flex then ask or you may have to buy yourself.
Message 18 of 35
I have just ordered, only activated this month, do you think this will be the best option then?
Would these mix ok with my current TP Link ones?
Could I just use one of the BT ones with the BT box and one of my TP link ones connected to the Hub? Otherwise I'd need a power socket pass through type
Message 19 of 35
Well came back in and BT sport channel blank, tried SD and blank. IPC6011 error...grrrrr
Message 20 of 35
Are you able to connect the Hub direct to your BT TV box and check what you get?  This would help elliminate or confirm that your powerline is at fault
Also, does your powerline have two ethernet port connections, and you have PS4 and BT TV plugged into each?
