GazzaP
Message 1 of 3
BT HH3 & Smart Wireless feature
Hi All
First time user on the forum so apologies if I haven't posted this query in the right place. I have inadvertently disabled the smart wireless feature on the HH3 and I cannot find any reference to how I can re-enable it (I inadvertently disabled it when I manually chose a different wireless channel). I have found this facility useful before.
Is there any way to re-activate it?
Many thanks
2 REPLIES 2
john46
Message 2 of 3
Re: BT HH3 & Smart Wireless feature
selecting a channel manually is the best option smart wireless only selects 1 of 3 channels which every one using smart wireless is using
gg30340
Message 3 of 3
John is correct that it is best to select a channel that gives you the best speeds but if you want to turn Smart Wireless back on follow this guide
http://bt.custhelp.com/app/answers/detail/a_id/32235
