MagicMikeyB
Message 1 of 6
BT HH3 and BST sync an hour out
Hi has anyone had the same issue. When trying to sync the HH to BST it puts it an hour behind. i.e if the time was 7pm it would change it to 6pm.
Any help would be appreciated
Hub Firmware Information
Current firmware:Version 4.7.5.1.83.8.57.1.3 (Type A)
Last updated:13/05/11
5 REPLIES 5
Aarong
Guru
Message 2 of 6
Re: BT HH3 and BST sync an hour out
Any day light saving on the hub?
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
jjgraphics
Recognised Expert
Message 3 of 6
It's a firmware problem in the HH3. There is much discussion about this on other threads in the forums. BT have promised a fix, but don't hold your breath!
Ectophile
Distinguished Guru
Message 4 of 6
It's not just the Hub 3.  My Hub 1.5 has been an hour out since BST started.  Never mind, it'll be fixed in October!
NewtronStar
Expert
Message 5 of 6
Just set the Time Manually and when BST/DST ends on the 28 October 2012 you can then set it back to Automatic ,hopefully Smiley Indifferent
Travelusa
Expert
Message 6 of 6
There is a rumour tht they may fix it for the GMT change over
