Message 1 of 8
BT HH3 (worst router EVER!)
Im not posting because I want your help, I'm quite capable of helping myself.
Im posting to vent my frustration with BT shipping out **bleep** hardware and charging me P&P for the privilege.
The HH3 cant even hold a wireless connection for longer than 5 minutes.
Has nothing to do with channels
Has nothing to do with devices
Has nothing to do with b/g/n wireless standards (though knowing BT, nothing is standard)
Has nothing to do with encryption settings
Has nothing to do with user error
HAS EVERYTHING TO DO WITH cheap **bleep** hardware
7 REPLIES 7
Expert
Message 2 of 8
Re: BT HH3 (worst router EVER!)
try disable the auto channel switching.
Also why did you pay for P&P. A new connection means free new hardware.
Im afraid you got bumped.
Over the past 6 years Ive got new equipment every 12 months for free (no charges at all)
Message 3 of 8
LOL I'm not surprised, I've been "bumped" every day as a BT customer, so I'm used to it anyway!
Check this out, somebody please explain the logic to me....
BT Infinity modem, plugged in since engineer install
Homehub 3 connected - I get 37mb/s down
Draytek router connected - I get 22mb/s down
Seems like anti-competetive behaviour to me, considering both routers were connected to the same **bleep**ing modem
Message 4 of 8
So lets get this straight HH3 gives 37 Mb/s and the Draytek gives 22 Mb/s so in what way is the HH3 the worst router ever?
Seriously something is screwed somewhere can you run the BT Spedtester to check the IP profile as that will indicate what your modem is syncing at. Know you did not want help. Where in the UK are you as there are problems in the NW tonight.
Message 5 of 8
Look its simple
plug in HH3, do speedtest, look at result
plug in draytek, do speedtest, look at result
rinse & repeat
You've missed the point, the modem is syncing to a speed and it passes its data over an ETHERNET cable, how the **bleep** does 15mb/s vanish across a few metres of CAT5e cable, depending on what router is connected!
Message 6 of 8
This draytek router has been plugged into a Virgin cable modem and achieved over 50mb/s easily, so nothing wrong with the router. Must be BTs anti-competetive nature thats the problem here
Message 7 of 8
I am not missing your point as there is no explanation if the tests were really done back to back and nothing else changed so I was suggesting you lookat what else may have changed.
There is no way I can see where BT can configure a PPPOE connection to favour their router over another and the modem uses a vanilla PPPOE interface. Other users have reported using a wide range of routers with no issue. Unless BT have configured your modem to spy on you of course?
For the record the HH3 is not the best router in the world but it is far from being the worst as it works well for hundreds of thousands of users. Like all ISP provided routers it is locked down and produced to a price to minimise product and support costs.
Clearly you meant it when you said you did not want help.
Distinguished Guru
Message 8 of 8
So after you switched off one router and plugged in the next one did you leave it before you ran a speedtest?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
