orange_dude
Message 1 of 8
BT HH5, Raspberry Pi, DHCP
I've just got my HH5 and have a bit of an odd problem and a couple of questions.
On the Devices page, what does the D in a blue circle signify?  It seems to be associated with IPv6 addressing.
Not all devices get the "D" and the IPv6 entry.  Any idea why?
My problem is that whenever I try to give one of these 2 devices a new name, both change.  They are Raspberry Pis
I've done  a factory reset but it is still happening.
BT Home Hub 5 (Type B) | Software version v0.07.05.0A13-BT  | Last updated 29/1/2016
It also happens to wireless connected Raspberry Pis too BUT is OK with laptops/tablets/webcams that connect wirelessly.  Is it a "feature" of the RPi on HH5?  It was fine with HH3
7 REPLIES 7
ChrisFWood
Message 2 of 8
Re: BT HH5, Raspberry Pi, DHCP
How are you changing the name of the RPi's?
imjolly
Message 3 of 8
 D for DHCP and a 6 for IPv6
orange_dude
Message 4 of 8
I changed the names from Home Network then Devices click on the IP/MAC address and change the name in the Home Network Name box. Then Apply
ChrisFWood
Message 5 of 8
I think it might be that the RPi told the dhcp server I am called X so it has got them as the same device so when you change the name at the DHCP it updates both.
Try this
http://www.howtogeek.com/167195/how-to-change-your-raspberry-pi-or-other-linux-devices-hostname/
You might need to tell the HH5 to forget the MAC addresses.
orange_dude
Message 6 of 8
Hmmm, worked OK with the HH3. Maybe the HH5 is a bit more picky.
I'll have a go at your link and report back
orange_dude
Message 7 of 8
The devices appear OK with their appropriate name on the DHCP page but the Home Network-Devices page has no details of what is connected. When I click on the Device in the DHCP table I get switched back to the Home Network-Devices page whereas it used to open the details of the device.
When everyone has gone to bed, I'll re-boot the router
orange_dude
Message 8 of 8
All OK this morning thanks ChrisFWood.
The correct names are everywhere and I can make changes to each Device
