Message 1 of 14
BT HH5 and Airport Extreme, Static IPs and Windows Home Server
I am making the switchover from talktalk to BT infinity - my setup at the moment is that I have the talktalk modem/router in modem only mode - this allows me to keep all my internal newtwork- static IPs and port forwarding for my WHS as they were when I was with virgin media
From what I have read the HH5 can't be used in modem only mode and one of my options is to use my AEBS in bridge mode wiring it from LAN on HH to WAN on AEBS.
Does using the AEBS in bridge mode and turning off wireless of HH5 allow me to keep my internal network as is and will I still be able to access my server out and about or will I have to do the port forwarding on the HH5
13 REPLIES 13
Message 2 of 14
Re: BT HH5 and Airport Extreme, Static IPs and Windows Home Server
Much simpler to just buy an Openreach modem from the well known auction site or a Draytek VDSL modem.
Message 3 of 14
I think the draytek is out of my price range Smiley Surprised
I have been looking on that well known auction site, are all the openreach modems capable of the same?
Message 4 of 14
The Huawei ones have G.Inp capability, the ECI ones don't. You don't need an unlocked one unless you want to look at detailed line stats.
Message 5 of 14
How can you tell which is which?
Message 6 of 14
The listing should say which type it is.
Message 7 of 14
Message 8 of 14
It does on most of the listings. If it doesn't say which type it is, I would suspect it is an ECI one as the Huawei ones attract a better price due to their G.Inp capability.
Message 9 of 14
Thanks for the replies - I'm not on superfast, I get 11Mb just now on regular talktalk BT say I can expect 15-22Mb when I make the change
Will it matter much if I get ECI over G-Inp?
Message 10 of 14
It depends on the condition of your line and what manufacturer cabinet you are connected to. G.Inp is a technology that deals with impulse noise on a line in a more effective way than applying the traditional methods of error correction and results in less of a speed drop. If your line is susceptible to noise, G.Inp will be a better option, if it is a good line then it won't matter. If price is more critical than every last Mbs of speed then ECI is perhaps the way to go.
