Message 1 of 6
BT HUB 5 Cat5,5E, Cat6 or Cat 7
I'm i want to move the router in the front room from the stairs so I'm getting a High quality ADSL cable (5M) and an Ethernet cable so I can connect it to my laptop. What's the maximum Cat number the BT HUB 5 can support? Would there be any point in getting cat 7?
5 REPLIES 5
legitimise_sailing
Distinguished Expert
Message 2 of 6
Re: BT HUB 5 Cat5,5E, Cat6 or Cat 7
You only need to get CAT5
To say thanks for a helpful answer, please click the white star
conrad
Recognised Expert
Message 3 of 6
If you want to 'future proof' then Cat6 is better - the price increase over Cat5 is minimal nowadays. Forget Cat7.
Ectophile
Distinguished Guru
Message 4 of 6
You'd struggle to get cat5 these days - it's obsolete and replaced by cat5e.  Over short cable runs, cat5e can to 1 Gbps.  You could use cat6 as an alternative.  I'd never even heard of cat7.
I see cat7 class F is supposed to handle 10 Gbps.  But the Home Hub can't do that speed, and most devices won't either.
Dode
Expert
Message 5 of 6
I got a Cat6 from Maplin, not because a wanted Cat6 but because it was flat and tucks down the side of carpets etc. Makes it very easy to route.
Message 6 of 6
lol this post takes me back, can't believe i was such a noob Smiley LOL
