eddy55
Message 1 of 2
BT HUB 5
I have a BT Hub 3 and am on normal Broadband at the moment.  I change to BT Infinity second week in April.  I am being sent a BT Hub 5   2 days before connection to Infinity.  When I receive the BT Hub 5 it says I have to check it is working so do I disconnect my BT Hub 3 and start using the Hub 5 on my normal broadband connection or do I wait and start using the BT Hub 5 once BT Infinity has been connected which will be 2 days after I receive the Hub 5.
1 REPLY 1
imjolly
Message 2 of 2
Re: BT HUB 5
you can connect right away if you want - plug and play
