Hi All,
I have:
- BT HUB Smart 2
- 2 Discs
- Internet FTTP at D:930Mbps (Cable) and U:120Mbps (these are measured speeds and various times in the day/night. Very stable)
PROBLEM(s):
- The fastest WIFI (router) speeds I was able to achieve was on my OnePlus 6T around 400Mbps (but usually 200 to 300) which is good but the sync speed is around 800mbps. (I always get the 120Mbps Up)
- Any of the 2 discs only allow me to to go up to 180-200 Mbps and again sync speed is always more than double what I get (throughput).
QUESTION:
are these the WIFI speeds I should be expecting? are these limited by the WIFI physics or by the particular hardware? Is there something that allows much higher WIFI speeds?
CF
