Anonymous
Not applicable
Message 21 of 23
Re: BT Home 500 Wi-Fi Extender & Hotspot Kits
@licquorice
Extenders don't have an IP address but the mini hotspot does, however you can't see it in the hub manager, you need to launch the BT Device Configuration Tool for that.
Even then it's not much use as entering the IP address into a browser just sends you to a very limited web server
Message 22 of 23
@Anonymous wrote:
@licquorice
......where you can set a static IP address and change the SSID and password etc.
@grandsire02  Just to be absolutely clear, can you confirm you only have one extender connected to the hub and not two?
Message 23 of 23
I definitely have only the one connected!
