pauljones
Newbie
Message 1 of 2
BT Home Hub 2 - WPA key renewal timer
Does anyone know how to find out the timer which governs when the WPA transmission key gets updated? I encountered an issue with one particular laptop dropping wireles connection every 10 minutes; if I revert to no security on the home hub it works just fine. Maybe this is a client end configuration issue rather than a router one, especially as another WPA configured laptop works fine. Any ideas welcome.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT Home Hub 2 - WPA key renewal timer
Navigate to Network and Sharing Centre - you can simply click start and type network, then look for it in the results
On the left look for Manage Wireless Networks
See if you've got multiple networks that are for the same Homehub (ie BTHomeHub2-A1B2)
Right click on all bar one that are the same and remove them or remove all hub connections (if the same) and start a fresh connection.
If you opt for the latter, when the connection is made, tick the box that says save this network.
Any joy?
-+-No longer a forum member-+-
